Problems building RTEMS on macOS Mojave
George Neville-Neil gnn at neville-neil.com
Thu Nov 8 15:51:10 UTC 2018
Howdy,
I've been trying to follow these directions to build RTEMS on macOS
Mojave:
https://docs.rtems.org/branches/master/user/start/index.html
But, I get a build failure every time, logs attached though here's the
end of the log in case it jogs memories etc.
Setting top to                           :
/Users/gnn/Repos/git/rtems/rsb/rtems/build/rtems-tools-36fde5169aef5b0af37f951907705caee76626ee-1/rtems-tools-36fde5169aef5b0af37f951907705caee76626ee
Setting out to                           :
/Users/gnn/Repos/git/rtems/rsb/rtems/build/rtems-tools-36fde5169aef5b0af37f951907705caee76626ee-1/rtems-tools-36fde5169aef5b0af37f951907705caee76626ee/build
Version                                  : 5.9955b1a43067-modified (5)
Checking for program 'python'            :
/usr/local/opt/python at 2/bin/python2.7
Checking for python version >= 2.6.6     : 2.7.15
Checking for 'clang' (C compiler)        : /usr/local/bin/clang
Checking for 'clang++' (C++ compiler)    : /usr/local/bin/clang++
Checking for header alloca.h             : not found
Checking for header fcntl.h              : not found
Checking for header process.h            : not found
Checking for header stdlib.h             : not found
The configuration failed
Thoughts on how to go about addressing/debugging this?  I've updated my
git repo to the latest as of 7 November 2018.
Best,
George
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20181108/7256df1e/attachment-0001.txt>
