Device driver initialization sequence
Ярослав Лещинский
midniwalker at gmail.com
Fri Nov 9 15:02:07 UTC 2018
I've tried the variant with posix descriptor and got an error when trying
to call close(fd). Program crashed with RTEMS_FATAL_SOURCE_EXCEPTION.
107 rv = IMFS_make_generic_node(
108 "/dev/gpio",
109 S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
110 &gpio_node_control,
111 NULL);
112
113 assert(rv == 0);
114
115 fd = open("/dev/gpio", O_RDWR);
116
117 if(fd < 0)
118 {
119 printf("stderr:[%s] at: [%d]\n", strerror (errno), __LINE__);
120 }
121
122 rv = ioctl(fd, SET_HIGH, NULL);
123
124 if(rv < 0)
125 {
126 printf("stderr:[%s] at: [%d]\n", strerror (errno), __LINE__);
127 }
128 */* Everything was ok until now*/*
129 rv = close(fd);
130 if(rv != 0)
131 {
132 printf("stderr:[%s] at: [%d]\n", strerror (errno), __LINE__);
133 }
It even didn't enter inside the if block line:132.
For test purpose I'm using such declaration of file handlers:
static const rtems_filesystem_file_handlers_r gpio_node_handlers = {
.open_h = rtems_filesystem_default_open,
.close_h = rtems_filesystem_default_close,
.read_h = NULL,
.write_h = NULL,
.ioctl_h = gpio_bus_ioctl,
.lseek_h = rtems_filesystem_default_lseek,
.fstat_h = IMFS_stat,
.ftruncate_h = rtems_filesystem_default_ftruncate,
.fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
.fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
.fcntl_h = rtems_filesystem_default_fcntl,
.kqfilter_h = rtems_filesystem_default_kqfilter,
.mmap_h = rtems_filesystem_default_mmap,
.poll_h = rtems_filesystem_default_poll,
.readv_h = rtems_filesystem_default_readv,
.writev_h = rtems_filesystem_default_writev
Could someone take a look and give some advice, seems like I made some
silly mistake.
On Fri, 9 Nov 2018 at 16:26, Ярослав Лещинский <midniwalker at gmail.com>
wrote:
> Hello Sebastian,
> Thank you. This looks like what I needed.
> On Fri, 9 Nov 2018 at 13:32, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Yaroslav,
>> the initialization sequence is documented here:
>> https://docs.rtems.org/branches/master/c-user/initialization.html#initializing-rtems
>> I would not use the I/O Manager. Working with major/minor numbers is
>> quite painful. I would initialize custom devices in the initialization
>> task. If you need the POSIX file descriptor API for your devices, then I
>> would use IMFS_make_generic_node() to register them.
>> On 09/11/2018 11:25, Ярослав Лещинский wrote:
>> > Hello,
>> > I read the documentation about I/O Manager, found different source
>> > codes where mentioning not only rtems_io_* functionality but also
>> > drvmgr*, rtems_libio* and another mechanisms which are referred to
>> > device driver topic and I have a feeling that I'm missing something.
>> > Could you please correct me if I'm wrong in the following steps of
>> > initialization of device driver:
>> > 1. define *CONFIGURE_MAXIMUM_DRIVERS* macro
>> > 1. Create *rtems_driver_address_table *and register it via
>> > *register_io_register_driver*
>> > 2. Write all necessary functions for *rtems_io_initialize,
>> > rtems_io_open, etc*
>> > 3. Associate name with major:minor pair using *rtems_register_name*
>> > As I understood there are can be a lot of different device drivers
>> > tables and I should somehow get the right major:minor driver from the
>> > right table. How I can do this?
>> > Kind regards,
>> > *Yaroslav Leshchinsky*
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/users
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Kind regards,
Kind regards,
URL: <http://lists.rtems.org/pipermail/users/attachments/20181109/81794e01/attachment.html>
