Cache routines working with a processor set?
Matthew J Fletcher
amimjf at gmail.com
Wed Nov 14 08:05:19 UTC 2018
Hi Sebastian
None of the above, but we used to
use rtems_cache_invalidate_entire_instruction
/ rtems_cache_invalidate_multiple_data_lines but now use arch specific
methods instead.
On Wed, 14 Nov 2018 at 06:21, Sebastian Huber <
> Hello,
> are the following cache manager routines used in an application or
> device driver code?
> * @brief Flushes multiple data cache lines for a set of processors
> * Dirty cache lines covering the area are transferred to memory.
> * Depending on the cache implementation this may mark the lines as
> invalid.
> * This operation should not be called from interrupt context.
> * @param[in] addr The start address of the area to flush.
> * @param[in] size The size in bytes of the area to flush.
> * @param[in] setsize The size of the processor set.
> * @param[in] set The target processor set.
> void rtems_cache_flush_multiple_data_lines_processor_set(
> const void *addr,
> size_t size,
> const size_t setsize,
> const cpu_set_t *set
> * @brief Invalidates multiple data cache lines for a set of processors
> * The cache lines covering the area are marked as invalid. A later read
> * access in the area will load the data from memory.
> * In case the area is not aligned on cache line boundaries, then this
> * operation may destroy unrelated data.
> * @param[in] addr The start address of the area to invalidate.
> * @param[in] size The size in bytes of the area to invalidate.
> void rtems_cache_invalidate_multiple_data_lines_processor_set(
> const void *addr,
> size_t size,
> * @brief Flushes the entire data cache for a set of processors
> * @see rtems_cache_flush_multiple_data_lines().
> void rtems_cache_flush_entire_data_processor_set(
> * @brief Invalidates the entire cache for a set of processors
> * This function is responsible for performing a data cache
> * invalidate. It invalidates the entire cache for a set of
> * processors.
> void rtems_cache_invalidate_entire_data_processor_set(
> I would like to remove these exotic, complex and very hard to use
> correctly functions.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> users mailing list
> users at rtems.org
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20181114/be4323f2/attachment.html>
