RTEMS5 File Descriptors
Wed Nov 21 07:00:04 UTC 2018
Hello Ian,
the file descriptors use now reference counting. In case you use a
closed file descriptor you get an error. The file descriptor list order
was changed to keep closed file descriptors as long as possible in the
closed state to improve the detection of a use after close.
In case you plan to switch to libbsd for networking, then using kqueue()
instead of select() is an option.
A quick and dirty hack would be to patch Newlib and set FD_SETSIZE to
your desired value.
If you have all your software under control, then you can also define
FD_SETSIZE yourself BEFORE you include <sys/select.h>.
You can also dynamically allocate the fd_set depending on
rtems_libio_number_iops, for example:
https://git.rtems.org/rtems-libbsd/commit/?id=4d8f9e62615d86a4f2d9b438da8276988277602f
https://git.rtems.org/rtems-libbsd/commit/?id=8ee0aa19cfc228a962d084bee805cb20bcd70f3b
https://git.rtems.org/rtems-libbsd/commit/?id=7ec4d8760dd98e647977fae76749609a81bdf6d2
I think we should mention this in the release notes.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
