installing python headers for RTEMS on OS X
Andrew Butterfield Andrew.Butterfield at scss.tcd.ie
Fri Nov 23 14:13:50 UTC 2018
Hi Chris, thanks for replying so quickly
> On 23 Nov 2018, at 00:07, Chris Johns <chrisj at rtems.org> wrote:
<stuff elided>
> My mail reader says the file has a size of 0.
oops - not sure what happenned here, but I think its irrelevant
> This is the MacOS provided python. The RSB gdb python check support must be
> finding python2 in the path posted. I do not think this is the standard one.
Later yesterday I did a build on another OS X machine and it seemed to work
 - no errors about python reported at least.
That machine only had the "standard OS X" versions of python.
The machine I was using when I sent this query in has homebrew installed python versions
(the clue here is the appearance of 'Cellar' in the -I path),
so I guess this is the problem. I'll discard those and retry - hopefully everything will work fine.
I'l let you know how I get on.
Regards, Andrew
Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
Lero at TCD, Head of Foundations & Methods Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
                         http://www.scss.tcd.ie/Andrew.Butterfield/
