users Digest, Vol 146, Issue 25
Arturo Perez Garcia arturo.perez at upm.es
Wed Nov 28 16:00:05 UTC 2018
I didn't call rtems_semaphore_release in the Init task, because the
initial count of the semaphore is 1. So that was not the case.
I followed the guidelines described in RTEMS C User Documentation
Release 4.11.3. Section 12.2 paragraph 2:
"A binary semaphore can be used to control access
to a single resource. In particular, it can
be used to enforce mutual exclusion for a critical
section in user code. In this instance, the
semaphore would be created with an initial
count of one to indicate that no task is executing
the critical section of code..."
Thanks
El 2018-11-28 13:00, users-request at rtems.org escribió:
> Send users mailing list submissions to
> 	users at rtems.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.rtems.org/mailman/listinfo/users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	users-owner at rtems.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of users digest..."
> Today's Topics:
>    1. Re: Task sync problems related with binary semaphore and
>       cache memories (Sebastian Huber)
> Message: 1
> Date: Wed, 28 Nov 2018 11:58:11 +0100
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> To: Arturo Perez Garcia <arturo.perez at upm.es>
> Cc: users at rtems.org
> Subject: Re: Task sync problems related with binary semaphore and
> 	cache memories
> Message-ID: <de80b7c0-3174-6fe0-d4ba-98dbc647b241 at embedded-brains.de>
> Content-Type: text/plain; charset=utf-8; format=flowed
> On 28/11/2018 11:52, Arturo Perez Garcia wrote:
>> Yes, I'm checking the return status always. When I create the RTEMS
>> objects and when I acquire/release the semaphore. I removed those
>> checks from the code I put in the previous message.
> Ok, good.
>> Thanks.
>> El 2018-11-28 11:42, Sebastian Huber escribi?:
>>> On 28/11/2018 11:30, Arturo Perez Garcia wrote:
>>>> Disabling the caches don't fixe the problem, I was wrong.
>>>> Maybe I'm initializing wrongly the RTEMS objects.
>>>> In the Init task I create the binary semaphore:
>>>> ?????? rtems_semaphore_create(a3_sem_name, 1, RTEMS_BINARY_SEMAPHORE
>>>> | RTEMS_FIFO | RTEMS_LOCAL, 0, &a3_sem_id);
> This call creates a binary semaphore without a locking protocol which
> is
> owned by the current task (Init task). If you do not call
> rtems_semaphore_release() for this semaphore within the Init task, then
> no other task should be able to obtain it.
> I would debug the rtems_semaphore_obtain() call if this is actually the
> case.
> Diese Nachricht ist keine gesch?ftliche Mitteilung im Sinne des EHUG.
> Subject: Digest Footer
> users mailing list
> users at rtems.org
> End of users Digest, Vol 146, Issue 25
Arturo Perez Garcia - arturo.perez at upm.es
Researcher
Center of Industrial Electronics
Universidad Politecnica de Madrid
