Problems with RTEMS toolchain build 4.12 & 5 incl. Ada support
Fri Nov 30 08:01:56 UTC 2018
Hello Chris,
I regularly build the RTEMS 5 tools with Ada support using the RSB, e.g.
cd $RSB/rtems
../source-builder/sb-set-builder --prefix=/opt/rtems/5 5/rtems-sparc
--with-ada
The host and target GCC versions must match to build Ada. So, building
the 6.3.0 RTEMS target GCC with a 7.1.0 host GCC will not work.
You must not have a previous installation in the prefix if you build new
tools with Ada support.
The documentation
https://docs.rtems.org/branches/master/rsb/building-tools-and-rtems.html#controlling-the-build
should probably be updated to mention this.
I would use the latest RTEMS.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
