wrong behavior binary semaphore
Arturo Perez Garcia
arturo.perez at upm.es
Fri Nov 30 10:24:27 UTC 2018
Here are the source files. I created a README file explaining the
intended goal of the semaphore under text. Under this context, I
developed the test. I also put the output obtained.
I hope these tests help you to find the root of the problems I'm
currently facing.
Thanks.
El 2018-11-30 09:56, Sebastian Huber escribió:
> On 30/11/2018 09:50, Arturo Perez Garcia wrote:
>> I reproduced the problem in a simple test. And I run it in the
>> zedboard and in the zcu102 obtaining the same results.
>> Where/how can I deliver it??
> This is great, can you attach the test sources to an e-mail to this
> mailing list?
Arturo Perez Garcia - arturo.perez at upm.es
Researcher
Center of Industrial Electronics
Universidad Politecnica de Madrid
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20181130/eabd95d4/attachment.bin>
