shell script problem
bin.wang at qkmtech.com
Mon Nov 19 11:21:07 UTC 2018
>Hi!
>- Where is this shell script from? (It doesn't really look like a shell script to me in any case, nor something you'd run in the RTEMS Shell.)
>- What are you trying to do? Where are you running the script and seeing the "cut off" at 128 characters?
>I don't see the script anywhere in any of the RTEMS repos yet (https://github.com/search?q=org%3ARTEMS+log_cmd&type=Code).
hi
rtems can run shell script .i just give my script.
log_cmd and log_idn is the shell command which i defined ,so i can use this script and do not need to input every command every time .
now i have no time to find the solution in the source. so i ask other people which is familar with the rtems shell script
best
ben
Date: 2018-11-19 19:23
To: bin.wang
CC: users
Subject: Re: shell script problem
Hi!
On Mon, Nov 19, 2018 at 4:10 PM bin.wang at qkmtech.com <bin.wang at qkmtech.com> wrote:
hi everyone:
i use the shell script as follows
#! joel
date
log_cmd 1 8 0
log_idn "p-0-0505.0.17" "p-0-0506.0.17" "p-0-0507.0.17" "p-0-0508.0.17" "p-0-0505.0.18" "p-0-0506.0.18" "p-0-0507.0.18" "p-0-0508.0.18"
log_cmd 1 8 1
date
the fourth line as follows has a problem , i can not get all part of the line
instead of
i just get as follows,which cut off the last part. i think maybe the max value is 128 .
how to change it to fit my situation?
thank you very much
best
ben
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20181119/9c8ea2bc/attachment-0002.html>
