rtems_message_queue_receive / rtems_event_receive issues
Tue Oct 2 06:55:10 UTC 2018
On 02/10/2018 08:48, Catalin Demergian wrote:
> Hi,
> This assert may not be directly related to my issue because I
> reproduced it a few times (with RTEMS_DEBUG enabled in the build)
> without seeing the assert being hit. What I discovered is that after a
> while _Scheduler_priotity_Unblock is not called for my task anymore.
> And since _Scheduler_priotity_Unblock calls _Scheduler_Update_heir, my
> task will not be set as the heir and no context switch will be made
> for it.
> My question is why would _Scheduler_priority_Unblock not beeing called ?
The _Scheduler_priority_Unblock() is called by _Thread_Unblock() only if
the thread state changes from not-ready to ready.
> rtems_event_send called from my USB ISR calls _Event_Surrender and
> that calls _Thread_Unblock
> Is there a conceptual problem calling rtems_event_send from an ISR ?
Using rtems_event_send() from an ISR is a standard use case.
> I saw there is a rtems_event_system_send function. should I call this
> one instead ? what is the difference?
It is a different event set, one for applications and one for the system.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
