rtems_message_queue_receive / rtems_event_receive issues
Fri Oct 5 07:06:42 UTC 2018
On 04/10/2018 15:33, Catalin Demergian wrote:
> I eliminated the theory of memory corruption. I debugged and found we
> set Wait.flags = 0x104 with a function call.
> The USB interrupt can arrive at any time, so Wait.flags can be either
> INTEND_TO_BLOCK, BLOCKED or READY_AGAIN.
> Following the logic in _Event_Surrender:
> If it arrives when Wait.flags = INTEND_TO_BLOCK
Are the flags == 0x101? In this case the thread is in the middle of
_Event_Seize()
> then _Thread_Wait_flags_try_change_critical will return TRUE,
> Wait.flags will be set to READY_AGAIN,
> unblock = FALSE so _Thread_Unblock will not be called.
The unblock is done in _Event_Seize() in this case:
   success = _Thread_Wait_flags_try_change_acquire(
     executing,
     intend_to_block,
     wait_class | THREAD_WAIT_STATE_BLOCKED
The success == false in this case.
> Then all the other USB interrupts will catch Wait.flags = READY_AGAIN
> and in this case_Event_Surrender doesn't do anything because unblock =
> FALSE
> .. so the task never runs again, but state remains marked as READY.
> is this a bug ? or I'm not understanding correctly?
There could be a synchronization issue with the wait flag or the
interrupt disable/enable sequence.
There was a severe bug on the ARMv7-M in this area, but it is fixed in
the 4.11.2 release:
https://git.rtems.org/rtems/commit/?h=4.11&id=7e91901303219f10cf865906931c07c31d2e37f4
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
