Purpose of Telnetd keep_stdio feature?
Tue Oct 9 12:15:24 UTC 2018
On 01/10/2018 08:26, Sebastian Huber wrote:
> Hello,
> the Telentd has a keep_stdio configuration option:
>    * @brief Keep standard IO of the caller.
>    * Telnet takes over the standard input, output and error associated
> with
>    * task, if this parameter is set to @c true.  In this case, it will
> @b not
>    * listen on any sockets.  When this parameter is @c false, Telnet will
>    * create other tasks for the shell which listen on sockets.
>   bool keep_stdio;
> What is the use case of this feature? Can I remove it?
I will remove this functionality to simplify the Telnet service:
https://devel.rtems.org/ticket/3542
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
