rtems_message_queue_receive / rtems_event_receive issues
Wed Oct 10 12:31:45 UTC 2018
On 10/10/2018 14:27, Catalin Demergian wrote:
> I was debugging to follow what's going on with the state of the task
> in _Event_Seize and
> when trying to step over _Thread_Dispatch_enable( cpu_self ) call at
> the end of the function I got this in the debugger
> 0x80acf38->_Heap_Walk->_Heap_Walk_check_control->_Heap_Walk_check_free_list->_Thread_Handler->_CPU_Thread_Idle_body
> heapwalk.c:331->heapwalk.c:240->heapwalk.c:105->threadhandler.c:95->armv7-thread-idle.c:33
>     if ( free_block->prev != prev_block ) {
> (*printer)(
> source,
> true,
> "free block 0x%08x: invalid previous block 0x%08x\n",
> free_block,
> free_block->prev
> return false;
> what does that mean? is this a memory corruption of some kind ?
> it seems the message "free block 0x%08x: invalid previous block
> 0x%08x\n" is printed somewhere, but I don't know
> how to see these messages in RTEMS, is there a command like dmesg in
> Linux ?
This looks more like a debugger issue which seems to have problems to
decipher the stack frame.
The _Thread_Dispatch_enable( cpu_self ) may lead to a context switch
which must be done via a supervisor call exception. If your debugger
disables this somehow you execute arbitrary code.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
