RTEMS in AMP mode
Thu Oct 11 11:20:58 UTC 2018
Hello Thawra,
On 11/10/2018 12:40, Thawra Kadeed wrote:
> Hello,
> please, I have a question about using RTEMS in AMP mode.
> In AMP mode we can boot RTEMS from one core and then it starts other
> cores with their own instances of RTEMS.
> The question is does the master RTEMS support running another version
> of RTEMS in other cores?
probably yes, since the MPCI support is quite static.
> For example, in case of 3 cores, the master RTEMS and the first slave
> are running the current RTEMS kernel (e.g. 4.11 to provide high
> performance), and the second slave is running a very old version of
> RTEMS (e.g. the 1990s to provide timing guarantees).
What is the problem with in the current RTEMS with respect to timing
guarantees?
> Is that possible using Gem5 simulation environment?
I never worked with Gem5.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
