rtems_message_queue_receive / rtems_event_receive issues
Thu Oct 25 09:17:04 UTC 2018
On 25/10/2018 11:00, Catalin Demergian wrote:
> Hi,
> First, I would like to conceptually understand how a function as
> simple as _Chain_Append_unprotected could fail.
The chain operations fail if you try to append a node that is already on
a chain or extract a node which is not on a chain.
> I added a patch like this
> RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(
>   Chain_Control *the_chain,
>   Chain_Node    *the_node
>   append_cnt++;
>   if(append_cnt > append_cnt_max)
> append_cnt_max = append_cnt;
>   Chain_Node *tail = _Chain_Tail( the_chain );
>   Chain_Node *old_last = tail->previous;
>   the_node->next = tail;
>   tail->previous = the_node;
>   old_last->next = the_node;
>   the_node->previous = old_last;
>   append_cnt--;
> I could see append_cnt_max=2 in the output bellow, meaning at some
> point there were two function calls
> in progress (don't know if it was for the same chain, as the patch
> dind't look if it's the_chain parameter is the same)
> How would be possible as a scenario to have two calls in the same time ?
Some chain operations are by a mutex and not interrupt disable/enable.
> I have to say that I even tried to temporary dis/en interrupts with
> __asm__ volatile ("cpsid i" : : : "memory") /__asm__ volatile ("cpsie
> i" : : : "memory")
> , but I could still reproduce. plus I also reproduced it
> with append_errs=0 .. I hope this doesn't break my theory :D
This is really strange. If you use cpsid/cpsie around the append_cnt ++
and --, then append_cnt should never be > 1. If this really the case,
then this looks like a processor bug.
> [/] # i
> Instruction count for the last second is 215992979.
> CPU load is 99.99%.
> intr_cnt=3220
> cond1=1
> cond2=1
> jiffies=1622210
> dbg_ready_UI1=287402
> dbg_ready_LOGT=374072
> dbg_ready_ntwk=1622094084077
> dbg_ready_SCtx=1621678898952
> dbg_ready_SCrx=1621678862701
> dbg_ready_SHLL=1622201084177
> dbg_extract_UI1=67127037
> dbg_extract_LOGT=67144458
> dbg_extract_ntwk=1622094096292
> dbg_extract_SCtx=1621678924213
> dbg_extract_SCrx=1621678883552
> dbg_extract_SHLL=1622200088846
> append_errs=0
> ready_queue_100_elems=1
> append_cnt_max=2
> [/] # assertion "first != _Chain_Tail( &ready_queues[ index ] )"
> failed: file
> "../../cpukit/../../../stm32f7/lib/include/rtems/score/schedulerpriorityimpl.h",
> line 232, function: _Scheduler_priority_Ready_queue_first
> *** PROFILING REPORT BEGIN PMC_APP ***
>   <ProfilingReport name="PMC_APP">
>     <PerCPUProfilingReport processorIndex="0">
>       <MaxThreadDispatchDisabledTime
> unit="ns">2</MaxThreadDispatchDisabledTime>
>       <MeanThreadDispatchDisabledTime
> unit="ns">1</MeanThreadDispatchDisabledTime>
>       <TotalThreadDispatchDisabledTime
> unit="ns">3369295</TotalThreadDispatchDisabledTime>
> <ThreadDispatchDisabledCount>3369216</ThreadDispatchDisabledCount>
>       <MaxInterruptDelay unit="ns">0</MaxInterruptDelay>
>       <MaxInterruptTime unit="ns">0</MaxInterruptTime>
>       <MeanInterruptTime unit="ns">0</MeanInterruptTime>
>       <TotalInterruptTime unit="ns">0</TotalInterruptTime>
> <InterruptCount>0</InterruptCount>
>     </PerCPUProfilingReport>
>   </ProfilingReport>
> *** PROFILING REPORT END PMC_APP ***
> Creating /etc/passwd and group with three usable accounts
> root/pwd , test/pwd, rtems/NO PASSWORD, chroot/NO PASSWORD
> I may have to begin the integration again for 4.11.3 ... are there any
> chances this might not reproduce in 4.11.3 ?
> are there any changes in this area ?
I don't think an update to 4.11.3 will solve your problem.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
