Console API
Mingyu Li
lmy2010lmy at gmail.com
Fri Oct 26 15:06:10 UTC 2018
Hi,
I think you are referencing the right documentation.
"rtems_termios_callbacks" should be what you need.
Would you tell me what exact platform you are working on? I recommend you
read the bsp source code that is mostly close to yours.
Please feel free to ask.
Best regards,
Maxul
Ярослав Лещинский <midniwalker at gmail.com> 于2018年10月26日周五 上午12:18写道:
> Hello,
> I'm working with a new BSP and now trying to add console implementation.
> I'm working on 4.11 branch.
> During the last try I've got such error:
> *error: unknown type name 'rtems_termios_handler'*
> Although the documentation here:
> https://docs.rtems.org/releases/rtems-docs-4.11.2/bsp-howto/console.html
> uses exactly such type name.
> Seems like I'm using the outdated API documentation. Could you please
> provide some info where I can get the actual reference documentation about
> 4.11 RTEMS Api.
> Thank you a lot.
> Kind regards,
> *Yaroslav Leshchinsky*
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20181026/8b81f519/attachment.html>
