Console API
Tue Oct 30 11:13:45 UTC 2018
On 30/10/2018 12:11, Ярослав Лещинский wrote:
> I checked out master branch and tried to add a new bsp. I found that
> in hello example now you are using another macro
> definition CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER instead
> of CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER like in 4.11.
> Seems like CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER doesn't call
This driver uses rtems_putc().
You can use the spconsole01 test to check your console driver.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
