cmsis licenses
Wed Oct 31 12:50:37 UTC 2018
Hello,
the recent CMSIS code has a proper license.
On 31/10/2018 12:00, Ярослав Лещинский wrote:
> Hello,
> Here I found the discussion about uses of CMSIS code:
> https://lists.rtems.org/pipermail/devel/2014-September/007974.html
> Also I found that in 2016 CMSIS was added to RTEMS code base:
> https://devel.rtems.org/log/rtems/c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/RTOS/Template/cmsis_os.h?rev=370c09a1f4012139aebabb4f2c9ec081855fc94d
> But now there are no CMSIS headers files. Is it prohibited to use
> CMSIS now or I I can use CMSIS files as a part of RTEMS project?
This code was removed during a general source tree cleanup since no BSP
used it at the time. If you need files from ST, then please try to
integrate the latest version.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
