imx6ULL memcpy issue in RTEMS 5
Ian Caddy ianc at goanna.iinet.net.au
Tue Sep 4 08:13:31 UTC 2018
Hi All,
I am trying to get a imx6ULL custom BSP running on RTEMS 5.  I am
working through some startup issues between u-boot and RTEMS and I think
I have most of them squared away now.
During the RTEMS higher level init, the IMFS is inited and as part of
that, /dev is created.  When creating the node for the "dev" directory, in:
rtems/cpukit/libfs/src/imfs/imfs_creat.c:56
it performs a memcpy to place the name into the node->name:
memcpy(RTEMS_DECONST(char *, node->name), name, namelen);
where:
node->name = 0x8031c4B8
name = "dev" @ 0x8029aff1
namelen = 3
At the lowest level memcpy calls:
gcc-7.3.0/newlib/libc/machine/arm/memcpy-armv7a.S
which at line 236 performs a half word load from the source (which is
not aligned, not the name address above):
  ldrhcs tmp1, [src], #2
and I get a data abort as src = 0x8029aff1 which is a const string and
has no reason to be word (or half word) aligned.
I pretty much copied the build tree, from the imx BSP (which is based on
an imx7 I think from memory) as the imx6ULL is a Cortex-A7 single core
proceessor, using the ARMv7-A architecture.
Some places have been saying that I need to check whether or not the
particular processor support non-aligned access, but the imx
documentation is not that great and points to the ARM documentation
which is more generalised.
There seemed to be a similar issue on the GNU embedded toolchain mailing
list:
https://answers.launchpad.net/gcc-arm-embedded/+question/289328
I can provide more detailed information if anyone is interested.
We are going to need to be able to support unaligned access for memcpy
on both the source and destination, so I was hoping someone might be
able to point me in the correct direction to fix it?
regards,
Ian Caddy
