Upper limit for BSS on SPARC BSP ?
Hugues Jérôme hugues.jerome at gmail.com
Wed Sep 5 13:45:31 UTC 2018
Hi Sebastian,
> Le 5 sept. 2018 à 14:20, Sebastian Huber <sebastian.huber at embedded-brains.de> a écrit :
> Hello Hugues,
> On 05/09/18 14:02, Hugues Jérôme wrote:
>> Hi,
>> I’m investigating a memory alignement issue using the GR740 BSP.
>> It appears we have a memory corruption when the BSS is bigger than 4MB.
> does the ELF file look all right? Is the stack pointer at the end of RAM right at the entry point (start)? Is the BSS section properly zeroed in the startup sequence?
I’m not sure I can provide any positive answer to these questions.
We used the default GR740 BSP, compiled by Thanassis Tsiodras. We did not change anything
As far as i can see, the BSS is zeroed by start.S
do you have any recommendation to perform the diagnosis you prescribe ?
As far as I can provide details
size (from binutils) can parse the ELF file, but that does not mean a lot
stack pointer is set by the linker script (if I understood correctly this part), and we did not change it
Regards,
