RISC-V RTEMS Support
Slide
slide.o.mix at gmail.com
Thu Sep 6 06:28:00 UTC 2018
Hi Sebastian,
Is your work for both RV32 and RV64? Does it support MMU or just PMP?
Thanks!
Alex
On Wed, Sep 5, 2018, 22:29 Sebastian Huber <
> Hello Dwaine,
> I finished my work to add SMP support to the RISC-V architecture for
> RTEMS. It is now on par with the ARM, PowerPC and SPARC ports. I had
> only a two hart system for testing (FPGA based). It would be nice to get
> some funding to add support for high end targets such as:
> https://www.sifive.com/products/hifive-unleashed/
> A ready to use SoC for a low budget FPGA development board would be also
> quite nice. The SiFive evaluation SoC for the Digilent Arty board has no
> memory controller and 16KiB internal RAM are not enough to run the RTEMS
> testsuite.
> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180905/352c5ced/attachment.html>
