rtems_message_queue_receive / rtems_event_receive issues
Catalin Demergian
demergian at gmail.com
Tue Sep 18 12:20:33 UTC 2018
Hello,
I am using RTEMS 4.11.2 and I tried first to use RTEMS message queues in my
USB FS driver.
I'm populating the queue from the ISR and then use
rtems_message_queue_receive from a kernel task to
read the messages. After some debugging sessions I came to the conlusion
that rtems_message_queue_receive function
hangs even if there are messages in the queue. (manpage says it should
return immediately if there is at least one message
in the queue; in my case the queue gets full, but still the function hangs)
I tried then rtems_event_receive. I used my own queues and from ISR I only
called rtems_event_send; the same issue
happened again, this time rtems_event_receive hangs even if I see the event
was raised (with task command in the shell)
My question is: are there any known issues/bugs with these functions ?
thanks,
Catalin
URL: <http://lists.rtems.org/pipermail/users/attachments/20180918/3741e401/attachment.html>
