RTEMS 5 build on a Mac with the latest compilers?
groups at chichak.ca groups at chichak.ca
Wed Sep 19 06:24:31 UTC 2018
My initial tests look very promising. I did a clean pull and build and the ARM tools built without complaint.
I need to do more work on my STM32F767 BSP to get it into the new format, but the compile went through the motions well enough.
Andrei
> On 2018-September-18, at 19:08, Chris Johns <chrisj at rtems.org> wrote:
> On 19/09/2018 03:18, Mr. Andrei Chichak wrote:
>> I was wondering if anybody has tried to do a clean build if the HEAD with Apple’s latest version of Xcode?
> Not yet.
>> Apple dropped Xcode 10.0 yesterday with all fo the associated command line tools. Since these are used to build the RTEMS tools, it seemed to be a dangerous update.
> I saw this yesterday and I have not had a chance to fetch it and try. I forgot
> to kick off the install last night.
>> I always get a flinch when there is a .0 version compiler being dropped and I’m in the middle of a project.
> Sure. I have a machine here for just this purpose.
> The only recent issue I have seen is with APFS on high end MacBooks with large
> solid state disks. I thought we had a patch to work around the issue but I
> cannot find it in the RSB and I was building tools on that machine on the
> weekend without a problem so something must have been fixed.
> The only other problem I know of is a BSD vs GNU sed issue on FreeBSD and MacOS...
> https://gcc.gnu.org/bugzilla/attachment.cgi?id=41380
> Chris
