Unresolved Symbols using RTL on pc686
Hickey, Joseph P. (GRC-LSS0)[Vantage Partners, LLC] joseph.p.hickey at nasa.gov
Tue Sep 25 13:32:38 UTC 2018
On 09/25/2018 02:01 AM, Sebastian Huber wrote:
> On 24/09/2018 21:41, Hickey, Joseph P. (GRC-LSS0)[Vantage Partners,
> LLC] wrote:
>> I'm currently seeing some unexpected behavior where references to
>> non-initialized global variables inside a loaded module are not
>> getting resolved properly after dlopen().I'm using RTEMS 4.11.3 with
>> the pc686 BSP.
> maybe it helps to build everything with -fno-common.
Thank you Sebastian for this suggestion.  I have tried building with
-fno-common and indeed this seems to do the trick.
I have also submitted bug #3527 as suggested by Chris.
Thanks again for the advice!
