rtems_message_queue_receive / rtems_event_receive issues
Catalin Demergian
demergian at gmail.com
Wed Sep 26 08:38:25 UTC 2018
Hi,
Are you able to catch the interrupt, confirm the event is being raised and
the
interrupt exits via the RTEMS exit path?
-> Yes. I can see with task command in shell my USB event is set for my
task; the state is READY, but
if I enter cpuuse a few times I see the total CPU time for my task doesn't
increase, but for other tasks it increases.
I also see interrupts comming at every second (as ping send packets every
second) and my buffer of packets eventually gets full.
That's why I say that maybe something happens in the dispatcher, because
the dispacther should take tasks from the ready queue
and put them on the CPU.
regards,
Catalin
On Wed, Sep 26, 2018 at 10:54 AM Chris Johns <chrisj at rtems.org> wrote:
> On 26/09/2018 16:43, Catalin Demergian wrote:
> > When you say "changing the makefiles" who's makefiles are these?
> > -> for example lib/rtems-4.11.2/c/src/lib/libbsp/arm/stm32f7/Makefile.am
> > in order to include my USB .c and .h files
> Thanks.
> > Did you merge your code into the RTEMS
> > source tree?
> > -> yes, there was no support for USB in the code base I had
> Sure and thanks.
> RTEMS is statically linked so object files built as part of RTEMS or files
> build
> as part of your code are equivalent.
> I will often create a small application to test new drivers or a new
> feature for
> RTEMS that do not touch the core RTEMS kernel code. I do this because the
> build
> is simpler and faster than rebuilding RTEMS on each edit. This means
> updating
> RTEMS is easy and the code I have is not effected.
> > Do you have a JTAG debugger that can set breakpoints and step at the
> instruction
> > level?
> > -> yes
> the
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20180926/0caa8839/attachment.html>
