rtems_message_queue_receive / rtems_event_receive issues
Catalin Demergian demergian at gmail.com
Wed Sep 19 12:46:55 UTC 2018
Hi,
thank you for answering !
I am using my own queues and rtems_event_send to notify my kernel task from
the USB ISR that a new packet arrived.
I found an interesting field in the TCB structure
  /** This field is the amount of CPU time consumed by this thread
   *  since it was created.
  Thread_CPU_usage_t                    cpu_time_used;
I added a new shell cmd to print this info after my kernel thread gets
stuck and I don't see this field changing at all !
*Could this mean that my task is not scheduled anymore ?*
by printing other values I can see that the task is in ready state and the
USB event is set. Also, the shell confirms this also
in the output of *task *command.
If the task is in ready state, why doesn't it run ?
Is the isr handler installed using an RTEMS interrupt service or is it a
raw hardware vector?
I installed the ISR myself like this
  // USB related initializations
_ARMV7M_Set_exception_priority_and_handler(ARMV7M_VECTOR_IRQ(STM32F7_IRQ_OTG_FS),
BSP_ARMV7M_IRQ_PRIORITY_DEFAULT, USB_OTG_Handler);
I am sure that the ISR is entered after the kernel task gets stuck.
regards,
Catalin
On Wed, Sep 19, 2018 at 5:58 AM Mingyu Li <lmy2010lmy at gmail.com> wrote:
> Hi Catalin.
> I find the problem you encountered interesting. I hope to offer some hints
> that might be helpful to you:
> 1. use a user task to first rtems_event_send then rtems_event_receive, in
> order to make sure the internal IPC of RTEMS kernel you are using (4.11.2)
> works as expected.
> 2. ensure to disable/lock interrupts while operating the message_queue inside
> USB ISR. Try to check if clock ISR is still responded when USB ISR exits,
> so that the kernel task can be scheduled to obtain the message.
> Best regards,
> Mingyu
> 2018-09-18 20:20 GMT+08:00 Catalin Demergian <demergian at gmail.com>:
>> Hello,
>> I am using RTEMS 4.11.2 and I tried first to use RTEMS message queues in
>> my USB FS driver.
>> I'm populating the queue from the ISR and then use
>> rtems_message_queue_receive from a kernel task to
>> read the messages. After some debugging sessions I came to the conlusion
>> that rtems_message_queue_receive function
>> hangs even if there are messages in the queue. (manpage says it should
>> return immediately if there is at least one message
>> in the queue; in my case the queue gets full, but still the function
>> hangs)
>> I tried then rtems_event_receive. I used my own queues and from ISR I
>> only called rtems_event_send; the same issue
>> happened again, this time rtems_event_receive hangs even if I see the
>> event was raised (with task command in the shell)
>> My question is: are there any known issues/bugs with these functions ?
>> thanks,
>> Catalin
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180919/372444d7/attachment-0002.html>
