RISC-V RTEMS Support
Molock, Dwaine S. (GSFC-5820)
dwaine.s.molock at nasa.gov
Thu Sep 20 16:58:34 UTC 2018
Hello Sebastian,
Which FPGA development board and RISC-V design did you use for implementation and testing?
Did you use the generic or patched version of QEMU?
Thanks,
Dwaine
> On Sep 6, 2018, at 2:31 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Hello Alex,
> On 06/09/18 08:28, Slide wrote:
>> Hi Sebastian,
>> Is your work for both RV32 and RV64?
> yes.
>> Does it support MMU or just PMP?
> The BSP performs no low-level initialization and it doesn't touch the MMU or PMP. It runs in machine mode. To run in another mode more works is necessary.
> In general, RTEMS is not a micro kernel, so a MMU could be used only for static memory maps.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
