Problem with rtems5 on mvme2100 - hard-float/soft-float confusion
Joachim Rahn Joachim.Rahn at helmholtz-berlin.de
Mon Apr 1 07:45:28 UTC 2019
Hello all,
I've build rtems5-tools and rtesm5-system using rsb with enabled testsuites for target powerpc and rtemsbsp=mvme2100.
The build works fine so far but the testsuites are not running on mvme2100!
The first thing I recognized was, that unfortunately only the ELF-Files (.exe) from testsuites were
build but not the BIN-Files (.ralf). So it seems to me, that the bsp-post-link from make/custom/mvme2100.cfg wasn't
executed?!?
I then took https://git.rtems.org/examples-v2 and build it with the rtems5 tool chain.
In this case the rtems tool-chain builds both, the ELF and BIN files fine.
Trying out the hello_world.ralf on mvme2100 unfortunately gaves an error with stack and register dump!
Looking into the the produced binary hello_world.ralf one can see, that there is still the ELF magic at the
beginning of the binary file so it seems to me something goes wrong during link/load.
As a test and to get more warnings I then removed the "--no-warn-mismatch" option in "make/custom/mvme2100.cfg".
Now the make of hello_world breaks with error message:
powerpc-rtems5-ld: o-optimize/hello_world.exe uses hard float, /rtems/5/powerpc-rtems5/mvme2100/lib/bootloader.o uses
soft float
Seems to me, that unfortunately some rtems system code for mvme2100 was build with gcc option "-msoft-float" ???
Any hints are welcome...
Cheers, Joachim
Type: application/pgp-signature
Desc: OpenPGP digital signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20190401/7cc5b1ec/attachment.bin>
