RTEMS scheduler bug ?
Tue Apr 2 11:01:57 UTC 2019
On 02/04/2019 12:59, Catalin Demergian wrote:
> Hi,
> I was able to reproduce the issue again, but it doesn't look like the
> interrupts are enabled
> in the functions where you added Asserts in the patch. So, my changes
> don't fix the problem.
> My analysis would have been correct if the interrupts were enabled,
> but it looks it's not the case.
> Still, a problem exists somewhere .. _Chain_Append_unprotected fails
> and the task starves as a result.
> If it's not interrupts, I have to think again what could produce the
> failure. (any idea/hint here is welcome :) )
> Also, during my tests I even saw a crash (probably not related to this
> issue). Call stack looks like this
> Thread #1 (Suspended:Signal:SIGINT:Interrupt)
>  _ARMV7M_Exception_default() at armv7m-exception-default.c:25 0x805aff0
>  <signal_handler_called>() at 0xfffffffd
>  _Configuration_Scheduler_priority_dflt() at 0x2400063c
What is signal_handler_called()?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
