cant break a stm32 exe
Ian Caddy
ianc at goanna.iinet.net.au
Wed Apr 3 08:30:33 UTC 2019
Normally we would use 'c' instead of 'run'.
If you have downloaded your code, just use the c for continue for
embedded processors.
regards,
Ian Caddy
On 3/04/2019 3:48 pm, 787562067 wrote:
> hi, guys, how to debug this case
> Loading section .init, size 0xc vma 0x125ec
> Loading section .fini, size 0xc vma 0x125f8
> Loading section .rodata, size 0x16b8 vma 0x12608
> Loading section .ARM.exidx, size 0x8 vma 0x13cc0
> Loading section .eh_frame, size 0x3c vma 0x13cc8
> Loading section .init_array, size 0x4 vma 0x13d04
> Loading section .fini_array, size 0x4 vma 0x13d08
> Loading section .jcr, size 0x4 vma 0x13d0c
> Loading section .data, size 0x6ac vma 0x20001188
> Start address 0x189
> Transfer rate: 662944 bits in <1 sec.
> (gdb) info b
> No breakpoints or watchpoints.
> (gdb) b Init
> Breakpoint 1 at 0x3cc: file
> ../../../../../../../rtems-4.11.3/c/src/../../testsuites/samples/hello/init.c,
> line 168.
> (gdb) run
> Starting program:
> /home/cheng/stm32f4/arm-rtems4.11/c/stm32f4/testsuites/samples/hello/hello.exe
> [Inferior 1 (process 42000) exited normally]
> (gdb) n
> The program is not being run.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190403/d1aa99a1/attachment-0001.html>
