stm32f4 i2c problem
787562067
googcheng at qq.com
Thu Apr 4 01:48:44 UTC 2019
HI, i have tried some days to know stm32 i2c, almost make it , but i still can not read the data correctly
i think this is the right method, but dont know where i go wrong. please reply me
//add i2c pin config in io.h
#define STM32F4_PIN_I2C(port, idx, altfunc) \
.pin_first = STM32F4_GPIO_PIN(port, idx), \
.pin_last = STM32F4_GPIO_PIN(port, idx), \
.mode = STM32F4_GPIO_MODE_AF, \
.otype = STM32F4_GPIO_OTYPE_OPEN_DRAIN, \
.ospeed = STM32F4_GPIO_OSPEED_2_MHZ, \
.pupd = STM32F4_GPIO_NO_PULL, \
.af = altfunc \
#define STM32F4_PIN_I2C1_SCL STM32F4_PIN_I2C(1, 8, STM32F4_GPIO_AF_I2C1)
#define STM32F4_PIN_I2C1_SDA STM32F4_PIN_I2C(1, 9, STM32F4_GPIO_AF_I2C1)
#endif /* STM32F4_FAMILY_F4XXXX */
start-config-io.c
#endif
#ifdef STM32F4_ENABLE_UART_4
STM32F4_PIN_UART4_TX_PA0,
STM32F4_PIN_UART4_RX_PA1,
#endif
#ifdef STM32F4_ENABLE_UART_5
STM32F4_PIN_UART5_TX_PC12,
STM32F4_PIN_UART5_RX_PD2,
#endif
#ifdef STM32F4_ENABLE_USART_6
STM32F4_PIN_USART6_TX_PC6,
STM32F4_PIN_USART6_RX_PC7,
#endif
#ifdef STM32F4_ENABLE_I2C1
STM32F4_PIN_I2C1_SCL,
STM32F4_PIN_I2C1_SDA,
#endif
#ifdef STM32F4_ENABLE_I2C2
#error Not implemented.
#endif
the application code, using the stm32 i2c driver :
extern stm32f4_i2c_bus_entry *const stm32f4_i2c1;
rtems_task Init(rtems_task_argument argument)
puts( "\n\n*** i2c test begin ***\n");
LED_INIT();
LED_OFF();
uint8_t buf[20] = {0};
rtems_status_code sc = stm32f4_i2c_init(stm32f4_i2c1);
printf("the sc is %d\n", sc);
stm32f4_i2c_message msg = {0};
msg.addr = 0x50;
msg.read = false;
msg.len = 1;
msg.buf = buf;
buf[0] = 0x66;
sc = stm32f4_i2c_process_message(stm32f4_i2c1, &msg);
printf("the write status %d\n", sc);
rtems_task_wake_after(2);
memset(buf, 0, sizeof(buf));
msg.read = true;
msg.len = 1;
msg.buf = buf;
printf("the read status %d\n", sc);
sleep(1);
int i = 0;
for(i = 0; i < 10; i++)
printf("%x\t", buf[i]);
(void)rtems_task_delete( RTEMS_SELF );
but i can not read the data, log outputs:
the sc is 0
the write status 0
the read status 0
[09:32:46.369]Rx 0 0 0 0 0 0 0 0 0 0
URL: <http://lists.rtems.org/pipermail/users/attachments/20190404/636e0a61/attachment.html>
