SPARC-RTEMS5-GDB and RTEMS Fatal error !
Michel Macena mmacena.eng at gmail.com
Mon Apr 15 19:25:03 UTC 2019
Hi, I have compiled a code for an ERC32 target board and loaded it using
gdb,
the code:
#include <bsp.h>
> #include <stdlib.h>
> #include <stdio.h>
> rtems_task Init(
>   rtems_task_argument ignored
>     printf( "Hello World Michel\n" );
> /* configuration information */
> /* NOTICE: the clock driver is explicitly disabled */
> #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MAXIMUM_TASKS 1
> #define CONFIGURE_INIT
> #include <rtems/confdefs.h>
the gdb commands:
sparc-rtems5-gdb
> /home/inpe/rtems_exemplos/compile_test/hello_test/hello_exp.exe
> set serial baud 19200
> target extended-remote /dev/ttyS0
> load
> run
It loads the program perfectly, but I try the command "run" it says
that the program is already running. So I closed the session
and started a new one.  The session:
sparc-rtems5-gdb
> GNU gdb (GDB) 8.2.1
> Copyright (C) 2018 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
> http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.
> Type "show copying" and "show warranty" for details.
> This GDB was configured as "--host=i686-linux-gnu --target=sparc-rtems5".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
>     <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from
> /home/inpe/rtems_exemplos/compile_test/hello_test/hello_exp.exe...done.
> (gdb) set serial baud 19200
> (gdb) target extended-remote /dev/ttyS0
> Remote debugging using /dev/ttyS0
> trap_table ()
>     at
> /home/inpe/masters_project/src/rtems/c/src/lib/libbsp/sparc/erc32/../../../../../../bsps/sparc/shared/start/start.S:107
> 107      RTRAP( 0, SYM(hard_reset) );                  ! 00 reset trap
> (gdb) cont
> Continuing.
> [Inferior 1 (Remote target) exited normally]
> ../../gdb-8.2.1/gdb/thread.c:93: internal-error: thread_info*
> inferior_thread(): Assertion `tp' failed.
> A problem internal to GDB has been detected,
> further debugging may prove unreliable.
> Quit this debugging session? (y or n) y
> This is a bug, please report it.  For instructions, see:
When I use the command "cont" the program ran, but his was the ERC32 board
console output:
Hello World Michel
> Hello World Michel
> Hello World Michel
> Hello World Michel
> Hello World Michel
> Hello World Michel
> Hello World Michel
> Hello World Michel
> Hello World Michel
> Hello World Michel
> *** FATAL ***
> fatal source: 0 (INTERNAL_ERROR_CORE)
> fatal code: 5 (INTERNAL_ERROR_THREAD_EXITTED)
> RTEMS version: 5.0.0.0a9b45132c0144c1dc4b6b828a68608c21397ca4
> RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB
> 9a3e12e5820918057633798c3fe2a1f952fb4e56, Newlib 1d35a003f)
> executing thread ID: 0x08a010001
> executing thread name: UI1
It seems that that the code works but I don't get why the "FATAL" and also
the "tp" error in GDB.
Do you know what may be happening ?
Thanks !
URL: <http://lists.rtems.org/pipermail/users/attachments/20190415/70b6b362/attachment.html>
