pc686: --enable-rtems-debug not working
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Tue Apr 16 13:01:31 UTC 2019
Hello,
if I build the pc686 BSP with --enable-rtems-debug activated I can't run any of the testsuites examples, but get the following error:
$ qemu-system-i386 -append --console=/dev/com1 -no-reboot -serial stdio -monitor none -nographic  -kernel ./build/i386-rtems5/c/pc686/testsuites/samples/ticker.exe
i386: isr=0 irr=1
assertion "bsp_interrupt_is_valid_vector(vector)" failed: file "../../../../../../../../refex-rtems/c/src/lib/libbsp/i386/pc386/../../../../../../bsps/i386/shared/irq/irq.c", line 275, function: bsp_interrupt_vector_enable
*** FATAL ***
fatal source: 7 (RTEMS_FATAL_SOURCE_ASSERT)
fatal code: 1288832 (0x0013aa80)
RTEMS version: 5.0.0.be50969881b97180bf4fc1e2975efd41169e08bb
RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB 9a3e12e5820918057633798c3fe2a1f952fb4e56, Newlib 1d35a003f)
executing thread is NULL
It seems to stem from rtems/bsps/i386/pc386/clock/ckinit.c:165:
> bsp_interrupt_vector_enable( BSP_PERIODIC_TIMER - BSP_IRQ_VECTOR_BASE );
because "BSP_PERIODIC_TIMER - BSP_IRQ_VECTOR_BASE" equates to 0xFFFFFFE0, but the subsequent assert on bsp_interrupt_is_valid_vector() only allows vectors between 0 and 16.
The BSP still works with the option disabled, but it makes debugging more difficult.
Does someone has some guidance on this problem. I could remove the assert in bsp_interrupt_vector_enable, but I am a bit hesitant with simply removing things from core files.
Best regards,
   Jan
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
German Aerospace Center
Simulation and Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
Jan Sommer
Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
DLR.de/SC
