stm32f4 __wfi
Christian Mauderer christian.mauderer at embedded-brains.de
Wed Apr 24 06:59:24 UTC 2019
Am 24.04.19 um 02:35 schrieb Jython:
> yes, I need to do low power for stm32f4
> will this line work __asm__ volatile ("wfi");?
That line should be correct. Please note that the instruction is already
used in the armv7 idle thread:
https://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/armv7-thread-idle.c#n32
The stm32f4 is a Cortex-M4 so it's quite likely that this routine is
used. You can check by doing an "arm-rtems5-objdump -dS" on your file
and search for the idle body.
With kind regards
Christian
> On Tue, Apr 23, 2019 at 10:28 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     Am 22.04.19 um 09:47 schrieb Jython:
>     > HI, ALL!
>     > wfi
>     http://www.keil.com/support/man/docs/armcc/armcc_chr1359125004400.htm
>     > how can i call the arm __wfi?
>     > _______________________________________________
>     > users mailing list
>     > users at rtems.org <mailto:users at rtems.org>
>     > http://lists.rtems.org/mailman/listinfo/users
>     Hello Jython,
>     WFI is an assembler instruction. The Keil wrapper isn't available in
>     gcc. I know of no direct replacement. Most likely you need a gcc inline
>     assembly for that.
>     May I ask why you would need "wfi"? If you use a operating system, the
>     system typically handles such low level stuff for you. The only
>     application that springs to mind for that instruction is overwriting the
>     idle loop to save energy.
>     Best regards
>     Christian
>     embedded brains GmbH
>     Herr Christian Mauderer
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     Phone: +49-89-18 94 741 - 18
>     Fax:   +49-89-18 94 741 - 08
>     PGP: Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
