stm32f4 wakeup interrupt
Jython
googcheng at gmail.com
Wed Apr 24 08:00:01 UTC 2019
HI, ALL!
why the code stuck in wakeup handler while the RTC gets time work fine
i have checked some days, but no register error found, i suspect that the
handler function is the issue
// code
rtems_isr rtc_wakeup_handler(rtems_vector_number vector)
uint32_t STM32F4_RTC_ISR = (*(volatile uint32_t *)(0x4000280C));
// clear 10bit
if(STM32F4_RTC_ISR & (1<<10))
//printk("wak\n");
STM32F4_RTC_ISR &= ~(1<<10);
STM32F4_RTC_ISR &= 0xfffffbff;
volatile uint32_t EXIT_PR = *(volatile uint32_t*)0x40013C14;
printk("before clr %08x\n", EXIT_PR);
EXIT_PR |= 1<<22;
int i;
for(i = 0; i < 1000; i++) i = i + 1 - 1;
printk(" %08x\n", EXIT_PR);
the printed log attached, why the EXIT_PR bit22 not cleared
URL: <http://lists.rtems.org/pipermail/users/attachments/20190424/fc575403/attachment-0001.html>
rtc
after while BDCR 00008103
BDCR 00008103
after rtc_write_enable
enter init mode
prer 007F00FF
isr value 00000413
Secs 6Mins 6Hours 23Days 19Months 4Years 2019
final CR 00004405
prer 007F00FF
create timer ok
create uart timer ok
interrupt ok
interrupt ok
usart3 interrupt installed ok
rtc interrupt installed ok
wakeup block begin
will sett wutr
before set CR 00004005
after clear alarma WUCKSEL CR value 00004005
WUTR 00000032
**CR 00004405
isr value 00000033
clear line 22 exit flag
1s ticks 100
stack check 0
Stack usage by thread
ID NAME LOW HIGH CURRENT AVAILABLE USED
0x09010001 IDLE 0020006F60 - 0020007F5F 0020007F00 4080 Unavailable
0x0A010001 UI1 0020007F88 - 002000AF87 002000AD90 12272 Unavailable
isr level 0
usart 3 gps init
usart read buf len 44
cmd reply:
RDY
+CPIN: READY
SMS DONE
AT
OK
usart read buf len 11
cmd reply: ATE0
OK
usart read buf len 25
cmd reply:
460024985206706
OK
usart read buf len 6
cmd reply:
OK
usart read buf len 21
csq reply:
+CSQ: 27,99
OK
usart read buf len 95
csq reply:
+CPSI: LTE,Online,460-00,0x27BD,46372353,372,EUTRAN-BAND40,38950,5,5,-77,-912,-635,22
OK
usart read buf len 42
csq reply:
+COPS: 0,0,"CHINA MOBILE CMCC",7
OK
cereg reply:
+CEREG: 0,1
OK
csq reply:
OK
+NETOPEN: 0
usart read buf len 32
csq reply:
+IPADDR: 10.88.169.109
OK
command AT+CIPOPEN=0,"TCP","monitor.iok.la",18327
usart read buf len 23
ipopen reply:
OK
+CIPOPEN: 0,0
IPHEAD reply:
OK
tcp_send_data function begin
0d 0a
ipsend reply:
ready to send data
send tcp data reply:
OK
+CIPSEND: 0,5,5
tcp_send_data function end
tcp_send_data ok
gps frame GPRMC,094423.00,A,2232.27251,N,11401.13288,E,0.145,,210319,,,A at get_gps_data
before while
usart3 read buf len 300
Secs 35Mins 6Hours 23Days 19Months 4Years 2019
Secs 36Mins 6Hours 23Days 19Months 4Years 2019
usart3 read buf len 144
Secs 37Mins 6Hours 23Days 19Months 4Years 2019
Secs 38Mins 6Hours 23Days 19Months 4Years 2019
Secs 39Mins 6Hours 23Days 19Months 4Years 2019
usart3 read buf len 170
Secs 40Mins 6Hours 23Days 19Months 4Years 2019
Secs 41Mins 6Hours 23Days 19Months 4Years 2019
Secs 42Mins 6Hours 23Days 19Months 4Years 2019
Secs 43Mins 6Hours 23Days 19Months 4Years 2019
Secs 44Mins 6Hours 23Days 19Months 4Years 2019
Secs 45Mins 6Hours 23Days 19Months 4Years 2019
Secs 46Mins 6Hours 23Days 19Months 4Years 2019
Secs 47Mins 6Hours 23Days 19Months 4Years 2019
Secs 48Mins 6Hours 23Days 19Months 4Years 2019
Secs 49Mins 6Hours 23Days 19Months 4Years 2019
Secs 50Mins 6Hours 23Days 19Months 4Years 2019
Secs 51Mins 6Hours 23Days 19Months 4Years 2019
Secs 52Mins 6Hours 23Days 19Months 4Years 2019
Secs 53Mins 6Hours 23Days 19Months 4Years 2019
Secs 54Mins 6Hours 23Days 19Months 4Years 2019
Secs 55Mins 6Hours 23Days 19Months 4Years 2019
Secs 56Mins 6Hours 23Days 19Months 4Years 2019
Secs 57Mins 6Hours 23Days 19Months 4Years 2019
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00400000
00400000
before clr 00ô
