lib-bsd socket close issues
Sebastian Huber
Fri Apr 5 06:59:12 UTC 2019
On 05/04/2019 01:17, Chris Johns wrote:
> On 5/4/19 4:53 am, Matthew J Fletcher wrote:
>> Hi Sebastian
>> I used rtems_task_wake_after().
>> On Thu, 4 Apr 2019, 18:22 Sebastian Huber, <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> How do you wait. Is this a busy wait?
>> ----- Matthew J Fletcher <amimjf at gmail.com <mailto:amimjf at gmail.com>> schrieb:
>> > replying to myself.
>> > With a 1 second pause between socket() and close() and 512 sockets it will
>> > still ENOBUFS,.. without calculating it properly thats easily 10 minutes
>> > since the first socket was allocated,. that must be enough time to start
>> > freeing the socket buffers internally.
>> > On Thu, 4 Apr 2019 at 16:47, Matthew J Fletcher <amimjf at gmail.com
>> <mailto:amimjf at gmail.com>> wrote:
>> > > Hi,
>> > > I have noticed an issue with lib-bsd that the legacy stack does not have.
>> > > If have a loop that does
>> > > for (;;)
>> > > wait(100) // milliseconds
>> > > socket() // allocate
>> > > close() // free
> Are you able to make a small stand alone test?
Yes, a self contained test case would be helpful. I cannot reproduce the
issue with the modified test case in attached patch for libbsd.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20190405/36f508d9/attachment-0002.bin>
