Missing arm_switch_reg is blowing up the build. And time is going way too fast.
Tue Aug 6 00:02:34 UTC 2019
On 6/8/19 2:45 am, groups at chichak.ca wrote:
> Good morning.
> I did a pull to rebuild the tools and RTEMS from the head for STM32F4 and cpukit/libdebugger/rtems-debuger-arm.c blows up in function arm_debug_unlock_abort with ‘arm_switch_reg’ undeclared.
Ouch.
> This was working about a week ago when I used the same scripts to pull, build the tools, configure, and build RTEMS.
Could you please raise a ticket and assign it to me? Please paste in the RTEMS
configure command line.
I guess it will be related to a change  in the libdebugger ARM backend to
support a wider range of hardware (the beaglebone) and something has broken.
Thanks
