Release 5.0.0 not found
Joel Sherrill
joel at rtems.org
Tue Aug 6 13:49:38 UTC 2019
Although there does need to be a 5.x release, the www-new.rtems.org site
was/is an
experiment and shouldn't be treated as official.
As far as the release 5.x goes, all work toward making a release is done by
unpaid
volunteers. There are a number of tickets which need triaging and deferring
as a minimum.
Fixing is preferable. We aren't getting enough tool build results posted.
And there certainly
aren't enough BSP test runs being posted.
Sebastian and I periodically do tool builds on our preferred hosts but that
doesn't give
the broad coverage we need. I post results on a few simulators.
This ignores the time required to cut a release. Invariably something has
changed or
is broken that has to be fixed before a release can be made. It typically
takes 2-3
weeks to tidy everything up and package it.
I'm not blaming you. You just reported a broken link. I just thought it was
an opportunity
to point out the challenges in getting releases made.
--joel
On Tue, Aug 6, 2019 at 8:27 AM Steven Grunza <steven.grunza at gmail.com>
wrote:
> The link on https://www-new.rtems.org/release/ for the Latest Stable
> 5.0.0 is https://www-new.rtems.org/release/5.0.0/
> Selecting that link returns a "Not Found" error message:
> Not Found
> The requested URL /release/5.0.0/ was not found on this server.
> If 5.0.0 didn't happen then maybe the link should be removed or an
> explanation text ReadMe.txt added.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190806/77d37ee0/attachment.html>
