No console output on Custom Zynq Board
Andy James A.James at sstl.co.uk
Mon Aug 19 09:18:28 UTC 2019
I'm attempting to run the RTEMS "hello" sample application  on a custom Zynq board with 7030 device. I built and ran the  sample application on a Zybo Z7-10 without any issues.
My custom board uses UART0  and a 100MHz UART clock with 666MHz CPU clk , and I have changed the  BSP to suit these values. I have verified that the Zynq UART0 registers are correctly
set  and can get some console output via directly writing to the UART0  TxFIFO address at 0xE0000030, however printf does not give any output. Does anyone have any suggestions as to what I may have missed?
Thanks
Andrew James
The information contained in this message is intended for the addressee only and may contain sensitive information. If you are not the addressee, please delete this message and notify the sender; you should not copy or distribute this message or disclose its contents to anyone. Any views or opinions expressed in this message are those of the individual(s) and not necessarily of the organisation. No reliance may be placed on this message without written confirmation from an authorised representative of its contents. No guarantee is implied that this message or any attachment is virus free or has not been intercepted and amended.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190819/8cfbcf55/attachment.html>
