Prerequisites for chdir at Init() time.
Jonathan Brandmeyer
jbrandmeyer at planetiq.com
Wed Aug 21 19:34:04 UTC 2019
Are there any special pre-requsites to using the chdir system call
effectively in RTEMS?
I've got a function which unpacks a tarred up filesystem by chdir into
a chosen directory, unpacking the filesystem, and then chdir() back to
"/". If I call this function from the RTEMS shell, everything behaves
normally, and the files appear relative to the path I cd'ed into.
However, if I call it directly from Init(), it acts strangely. The
chdir() call reports success, and subsequent call to getcwd() returns
the directory that I chdir'ed into. However, the tarball gets
unpacked relative to the filesystem root.
chdir("/mnt/somepath") appears to succeed. A subsequent call to
getcwd() also returns the directory cd'ed into.
However, the subsequent unpacking of the tarball does so into the root.
I did some digging into the shell initialization code, and saw that
`rtems_shell_init_user_env()` is constructing a private user
environment for the shell thread. In the process of doing so, it
makes a suspicious system call: chroot("/").
Sure enough, adding chroot("/") early enough in my POSIX_Init() allows
subsequent chdir operations to have the right side-effects on creat()
and open() calls.
What's up with that? Is it intentional? Or is the shell's chroot()
covering up some deficiency in the way that the
`rtems_global_user_env` is getting initialized when the IMFS rootfs is
set up?
Thanks,
Jonathan Brandmeyer
