Mounting/Accessing SD-Card on BBB
    Nils Hölscher
    nilhoel1 at gmail.com
    Thu Aug 15 13:54:41 UTC 2019
Hi,
I when my app wants to open a file on the SD card dev=mmcsd-0-0 rtems
freezes.
Exact call is:
fd = open(file, O_RDONLY);
With file being the pru binary I want to upload.
Thanks,
Nils
On Tue, 13 Aug 2019 at 17:56, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Hello Nils,
> a third possibility: You could start a FTP server and push the file via
> network.
> Best regards
> Christian
> Am Dienstag, 13. August 2019 schrieb Nils Hölscher:
> > Hi,
> > Thanks for the input I will try the SD card first.
> > That way I won't have to alter the code when I want to run other stuff
> on the pru.
> > Best,
> > Nils
> > On Tue, 13 Aug 2019 at 17:32, Gedare Bloom <gedare at rtems.org> wrote:
> > You can also build the PRU image into the RTEMS binary. See
> > examples-v2.git/file_io/crc/init.c
> > On Tue, Aug 13, 2019 at 8:46 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
> > > Hello Nils,
> > > that's a bit odd. I attached an expected output below. Some guesses:
> > > - Did you add FAT file system to your application?
> > > - Is there some odd formatting on the SD? Normally at least the FAT
> > > partition used by U-Boot should be visible.
> > > - Is your BDBUF configuration OK?
> > > - Do you have enough file descriptors?
> > > Beneath that: If you only need something where you can put some files,
> > > you can try to connect a USB stick instead. Maybe that works better.
> > > Best regards
> > > Christian
> > > media listener: event = DISK ATTACH, state = INQUIRY, src = mmcsd
> > > media listener: event = DISK ATTACH, state = SUCCESS, src = mmcsd, dest
> > > = /dev/mmcsd-0
> > > media listener: event = MOUNT, state = INQUIRY, src = /dev/mmcsd-0
> > > mmcsd0: 4GB <SDHC TO 15.15 SN 000002F6 MFG 02/2017 by 25 DY> at mmc0
> > > 24.0MHz/4bit/65535-block
> > > media listener: event = MOUNT, state = FAILED, src = /dev/mmcsd-0
> > > media listener: event = PARTITION INQUIRY, state = INQUIRY, src =
> > > /dev/mmcsd-0
> > > media listener: event = PARTITION INQUIRY, state = SUCCESS, src =
> > > /dev/mmcsd-0
> > > media listener: event = PARTITION ATTACH, state = INQUIRY, src =
> > > /dev/mmcsd-0
> > > media listener: event = PARTITION ATTACH, state = SUCCESS, src =
> > > /dev/mmcsd-0, dest = /dev/mmcsd-0-0
> > > media listener: event = MOUNT, state = INQUIRY, src = /dev/mmcsd-0-0
> > > media listener: event = MOUNT, state = SUCCESS, src = /dev/mmcsd-0-0,
> > > dest = /media/mmcsd-0-0
> > > = /dev/mmcsd-1
> > > media listener: event = MOUNT, state = INQUIRY, src = /dev/mmcsd-1
> > > mmcsd1: 4GB <MMCHC MMC04G 5.8 SN 160D224B MFG 09/2014 by 112 0x0000> at
> > > mmc1 48.0MHz/8bit/65535-block
> > > media listener: event = MOUNT, state = FAILED, src = /dev/mmcsd-1
> > > /dev/mmcsd-1
> > > media listener: event = PARTITION INQUIRY, state = FAILED, src =
> > > /dev/mmcsd-1
> > > media listener: event = DISK ATTACH, state = INQUIRY, src = mmcsd1boot
> > > mmcsd1boot0: 2MB partion 1 at mmcsd1
> > > mmcsd1boot1: 2MB partion 2 at mmcsd1
> > > mmcsd1rpmb: 131kB partion 3 at mmcsd1
> > > On 13/08/2019 13:30, Nils Hölscher wrote:
> > > > Hi,
> > > > Thanks for the help.
> > > > I tried to use your code, but I always get "ERROR: SD could not be
> > > > mounted after timeout".
> > > > Even after raising the waiting time.
> > > > The sources I use start here:
> > > > https://github.com/nilhoel1/rtems-pru/blob/pruss-shell/main.c#L110
> > > > And my uart output is:
> > > > waiting for SD...
> > > > usbus0: 480Mbps High Speed USB v2.0
> > > > usbus1: 480Mbps High Speed USB v2.0
> dest
> > > > = /dev/mmcsd-0
> > > > ugen0.1: <Mentor Graphics OTG Root HUB> at usbus0
> > > > ugen1.1: <Mentor Graphics OTG Root HUB> at usbus1
> > > > uhub0: <Mentor Graphics OTG Root HUB, class 9/0, rev 2.00/1.00, addr
> 1>
> > > > on usbus0
> > > > uhub1: <Mentor Graphics OTG Root HUB, class 9/0, rev 2.00/1.00, addr
> 1>
> > > > on usbus1
> > > > /dev/mmcsd-0
> > > > /dev/mmcsd-0
> > > > /dev/mmcsd-0
> > > > media listener: event = MOUNT, state = FAILED, src = /dev/mmcsd-0-0
> dest
> > > > = /dev/mmcsd-1
> > > > /dev/mmcsd-1
> > > > /dev/mmcsd-1
> > > > /dev/mmcsd-1
> > > > /dev/mmcsd-1, dest = /dev/mmcsd-1-0
> > > > media listener: event = MOUNT, state = INQUIRY, src = /dev/mmcsd-1-0
> > > > media listener: event = MOUNT, state = FAILED, src = /dev/mmcsd-1-0
> mmcsd1boot
> > > > uhub0: 1 port with 1 removable, self powered
> > > > uhub1: 1 port with 1 removable, self powered
> > > > ERROR: SD could not be mounted after timeout
> > > > Thanks,
> > > > Nils
> > > > On Mon, 12 Aug 2019 at 18:01, Christian Mauderer <list at c-mauderer.de
> > > > <mailto:list at c-mauderer.de>> wrote:
> > > >     On 12/08/2019 07:28, Nils Hölscher wrote:
> > > >     > Hi,
> > > >     > Can anyone help me with this?
> > > >     > I need to access the BBB's SD-Card, so that I can load my pru
> > > >     example on
> > > >     > the pru.
> > > >     > Thanks,
> > > >     > Nils
> > > >     Hello Nils,
> > > >     take a look at the following application:
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/init.c#L64
> https://gitlab.com/c-mauderer/rtems-bbb/blob/master/apps/wifi-sample/libbsdhelper.c#L122
> > > >     You should mainly need the stuff from the
> libbsdhelper_init_sd_card()
> > > >     and libbsdhelper_wait_for_sd().
> > > >     Please note that the SD card needs quite some time to initialize
> on BBB.
> > > >     I haven't had a look at it why that is the case.
> > > >     Best regards
> > > >     Christian
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org
> > > > http://lists.rtems.org/mailman/listinfo/users
> > > users mailing list
> > > users at rtems.org
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190815/be44f2fa/attachment-0002.html>
