Print stack info using rtems_stack_checker_report_usage_with_plugin()
Fernando Domínguez Pousa
fdpousa at gmv.com
Thu Dec 12 13:20:55 UTC 2019
Sent: 10 December 2019 17:36
To: Fernando Domínguez Pousa <fdpousa at gmv.com>
Subject: Re: Print stack info using rtems_stack_checker_report_usage_with_plugin()
On Tue, Dec 10, 2019, 8:37 AM Fernando Domínguez Pousa <fdpousa at gmv.com<mailto:fdpousa at gmv.com>> wrote:
Hi all,
I’m interested in getting stack information via an UDP message with an ASCII log trace inside. Basically, I cannot get the information using a printf. I found the function rtems_stack_checker_report_usage_with_plugin(rtems_printer* printer) in order to get the information and send it using my UDP log function. So first of all I created a function called logPlugin (I used as exampled the plugin at printf_plugin.c):
static int logPlugin(void *context, const char *format, va_list ap)
(void) context;
return addLog(INFO, STACK,format, ap); /* First two arguments are used to classify message at reception*/
Then at rtems_stack_checker_report_usage_with_plugin calling scope:
rtems_printer printer;
printer.context = NULL;
printer.printer = logPlugin;
rtems_stack_checker_report_usage_with_plugin(&printer);
It is important to say that addLog puts the message in a circular buffer that other task will read and send the content using UDP.
When stack checker report usage is called, only the information header is printed: " STACK USAGE BY THREAD\n"
"ID NAME LOW HIGH CURRENT AVAIL USED\n"
Next, stack values are not printed correctly and I can only get a value that is constant and equal to the same memory location (in decimal). It is a correct guide to implement this? I do not know how to use the printer struct context variable, can this cause my problem?
Did you add CONFIGURE_ENABLE_STACK_CHECKER?
Yes, it was enabled.
Also it would be handy to have methods for obtain cpu and stack usage without relying on the printf hook
I developed a code to gather all the tasks stack information into a struct that can be retrieved via function. Then I pack this struct and sent it via Ethernet. Can I add my code to check.c in order to retrieve stack information without print it? Is this an intersesting feature for the community?
Regards,
Thanks in advance,
Regards,
________________________________
[cid:image001.gif at 01D5AF6C.02B3BC40]
Ingeniero de Software
Software Engineer
GMV
Isaac Newton, 11
P.T.M. Tres Cantos
E-28760 Madrid
Tel. +34 91 807 21 00
Fax +34 91 807 21 99
www.gmv.com <http://www.gmv.com/>
[cid:image002.png at 01D5AF6C.02B3BC40]<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.facebook.com_infoGMV&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=TVgsYD5kZtUVH9LulD6BpnRsdJjK7KKhwm0gExv79V0&e=>
[cid:image003.png at 01D5AF6C.02B3BC40]<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.twitter.com_infoGMV-5Fes&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=AKhuDTIEG9B5SSppSI9W2IZbCtlVN6Xxghmhqw_8xrs&e=>
[cid:image004.png at 01D5AF6C.02B3BC40]<https://urldefense.proofpoint.com/v2/url?u=https-3A__plus.google.com_-2BGmvcompany&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=aH_sTC6ItBsWu6XvQPqgmMi4brzX7wBHmPqFQ2FbfSc&e=>
[cid:image005.png at 01D5AF6C.02B3BC40]<https://urldefense.proofpoint.com/v2/url?u=http-3A__www.youtube.com_infoGMV&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=LeXn3Vd6znq0lx28JCcO0BUCbRxzg36aodelZfSy_QE&e=>
[cid:image006.png at 01D5AF6C.02B3BC40]<https://urldefense.proofpoint.com/v2/url?u=https-3A__www.linkedin.com_company_gmv&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=qQvn0q84_7QaJIvkgK7wpqkfzr7YoJNDa9KIA6w0TVQ&e=>
[cid:image007.png at 01D5AF6C.02B3BC40]<http://www.gmv.com/en/RSS>
[cid:image008.png at 01D5AF6C.02B3BC40]<http://www.gmv.com/blog_gmv/language/en/>
P Please consider the environment before printing this e-mail.
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users<https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwMFaQ&c=CIoxZ4z5BqFvKvSGFOTo726QZIiNTc_M9CmngT-Pla4&r=JJRyTkGL8xI4YFJLjo7JWw&m=ZnGDe8CiC5tUJJuEodtypPFjSXET23uigE7l-uSzLMY&s=dGxmP2gK5vUyNRX5UQVoMbmLLQ1K6M-QpFkFJfVYVEY&e=>
URL: <http://lists.rtems.org/pipermail/users/attachments/20191212/848da163/attachment-0001.html>
