AW: Building rtems-libbsd for pc686
Sebastian Huber
Tue Dec 17 09:47:23 UTC 2019
On 17/12/2019 10:35, Jan.Sommer at dlr.de wrote:
>> -----Ursprüngliche Nachricht-----
>> Von: Joel Sherrill [mailto:joel at rtems.org]
>> Gesendet: Montag, 16. Dezember 2019 15:33
>> An: Sommer, Jan
>> Cc:rtems-users at rtems.org
>> Betreff: Re: Building rtems-libbsd for pc686
>> On Mon, Dec 16, 2019 at 7:37 AM<Jan.Sommer at dlr.de> wrote:
>> Hello,
>> I tried to build the branch 5-freebsd-12 for the pc686 BSP of the current
>> RTEMS master.
>> The compilation stops at:
>> [ 64/1156] Compiling freebsd/sbin/sysctl/sysctl.c
>> ../../freebsd/sbin/sysctl/sysctl.c:72:10: fatal error: machine/pc/bios.h:
>> No such file or directory
>> #include <machine/pc/bios.h>
>> compilation terminated.
>> Waf: Leaving directory `/home/somm_ja/workspace/refex/rtems-
>> libbsd/build/i386-rtems5-pc686-minimal'
>> Build failed
>> -> task in 'objs02' failed with exit status 1 (run with -v to display more
>> information)
>> I tried to build the default and minimal buildset with the same results.
>> The missing bios.h is available in the full freebsd sources.
>> Do I need to use the freebsd-to-rtems.py script to integrate the missing
>> header into the freebsd directory or do I need to do something different?
>> The code worked on the pc at one point.
>> What is it getting from bios.h?
>> My first cut at it would be to import that file. Long term, we would probably
>> be better off if the PC BSP used more infrastructure from FreeBSD. The current
>> BSP
>> is marginally supporting non-legacy PCs.
> With some local changes I got rtems-libbsd to compile again, but only without the E1000 driver.
> If the driver is included I get linker errors because it depends on iflib_* functions.
> If I understand libbsd.py correctly then iflib.h is included in the build, but iflib.c is not.
> I don't really get how other BSPs get around this dependency. Or don't they use E1000 at all?
We only use libbsd on system on chips (m68k, arm and powerpc) without PCI.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
