RTEMS Release Snapshot: 5.0.0-m1912 (05 Dec 2019)
Heinz Junkes junkes at fhi-berlin.mpg.de
Tue Dec 17 12:59:39 UTC 2019
When I try to use this release and keep the naming (5.0.0-m1992)
I get the following error when  I try to build a bsp:
	mv -f $depbase.Tpo $depbase.Po
In file included from /home/epics/MVME2500/RTEMS_DEV/rtems-5.0.0-m1912/cpukit/include/rtems/score/basedefs.h:31:0,
                 from /home/epics/MVME2500/RTEMS_DEV/rtems-5.0.0-m1912/cpukit/score/cpu/powerpc/include/rtems/score/cpu.h:40,
                 from /home/epics/MVME2500/RTEMS_DEV/rtems-5.0.0-m1912/cpukit/include/rtems/system.h:23,
                 from /home/epics/MVME2500/RTEMS_DEV/rtems-5.0.0-m1912/cpukit/include/rtems.h:29,
                 from ../../../../../../rtems-5.0.0-m1912/c/src/../../cpukit/sapi/src/version.c:27:
../../../../../../rtems-5.0.0-m1912/c/src/../../cpukit/sapi/src/version.c: In function 'rtems_version_revision':
/home/epics/MVME2500/RTEMS_DEV/build/b-qoriq_e500/powerpc-rtems5/c/qoriq_e500/include/rtems/score/cpuopts.h:65:30: error: 'm1912' undeclared (first use in this function)
 #define __RTEMS_REVISION__ 0-m1912
../../../../../../rtems-5.0.0-m1912/c/src/../../cpukit/sapi/src/version.c:53:10: note: in expansion of macro '__RTEMS_REVISION__'
   return __RTEMS_REVISION__;
/home/epics/MVME2500/RTEMS_DEV/build/b-qoriq_e500/powerpc-rtems5/c/qoriq_e500/include/rtems/score/cpuopts.h:65:30: note: each undeclared identifier is reported only once for each function it appears in
../../../../../../rtems-5.0.0-m1912/c/src/../../cpukit/sapi/src/version.c:54:1: warning: control reaches end of non-void function [-Wreturn-type]
make[4]: *** [sapi/src/version.o] Error 1
make[4]: Leaving directory `/home/epics/MVME2500/RTEMS_DEV/build/b-qoriq_e500/powerpc-rtems5/c/qoriq_e500/cpukit'
make[3]: *** [cpukit] Error 2
make[3]: Leaving directory `/home/epics/MVME2500/RTEMS_DEV/build/b-qoriq_e500/powerpc-rtems5/c/qoriq_e500'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/epics/MVME2500/RTEMS_DEV/build/b-qoriq_e500/powerpc-rtems5/c/qoriq_e500'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/epics/MVME2500/RTEMS_DEV/build/b-qoriq_e500/powerpc-rtems5/c'
make: *** [all-recursive] Error 1
I guess the expansion of RTEMS_REVISION doesn't work with the "-".
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> Begin forwarded message:
> From: users-request at rtems.org
> Subject: users Digest, Vol 159, Issue 7
> Date: 5. December 2019 at 13:00:00 CET
> To: users at rtems.org
> Reply-To: users at rtems.org
> From: chrisj at rtems.org <mailto:chrisj at rtems.org>
> To: users at rtems.org <mailto:users at rtems.org>
> Subject: RTEMS Release Snapshot: 5.0.0-m1912 (05 Dec 2019)
> Message-ID: <mailman.6.1575547200.34903.users at rtems.org <mailto:mailman.6.1575547200.34903.users at rtems.org>>
> RTEMS Release Build - 5.0.0-m1912
> RTEMS 5 Release snapshot m1912 is avaliable for testing.
> It can be found at:
> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912 <https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912>
> Please test and report any issues to the user at rtems.org <mailto:user at rtems.org> or devel at rtems.org <mailto:devel at rtems.org>
> mailing lists or please raise a ticket.
> If you are part of the RTEMS testing program please build on your preferred
> host posting build and BSP test results to build at rtems.org <mailto:build at rtems.org>.
> This is a development release and may have errors and be unstable.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/2d78aed7/attachment-0001.html>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/2d78aed7/attachment-0001.bin>
