RTEMS Release Snapshot: 5.0.0-m1912 (05 Dec 2019)
Heinz P. Junkes
junkes at fhi-berlin.mpg.de
Thu Dec 19 12:33:27 UTC 2019
Hi Chris, another issue with the Release Snapshot and powerpc (qoriq_e500):
libbsd :
./waf configure --prefix=/home/epics/MVME2500/RTEMS/5.0.0-m1912
--rtems-bsps=powerpc/qoriq_e500 --buildset=buildset/default.ini
./waf
[1850/1940] Linking build/powerpc-rtems5-qoriq_e500-default/debugger01.exe
/home/epics/MVME2500/RTEMS/5.0.0-m1912/lib/gcc/powerpc-rtems5/7.5.0/../../../../powerpc-rtems5/bin/ld:
cannot find -ldebugger
collect2: error: ld returned 1 exit status
Waf: Leaving directory
`/home/epics/MVME2500/RTEMS_DEV/rtems-libbsd-5.0.0-m1912/build/powerpc-rtems5-qoriq_e500-default'
Build failed
-> task in 'debugger01.exe' failed with exit status 1 (run with -v to
display more information)
From Sebastian Huber I got already the info to remove
debugger01:epics at epics:~/MVME2500/RTEMS_DEV/rtems-
libbsd-5.0.0-m1912$ diff libbsd.py libbsd.py.fix
5107,5109d5106
< self.addTest(mm.generator['test-if-header']('debugger01',
'rtems/rtems-debugger.h',
< ['test_main'], runTest = False, netTest = True,
< extraLibs =
['debugger']))
which does it it.
Heinz
On 12/18/19 11:26 AM, Chris Johns wrote:
>> On 18 Dec 2019, at 6:52 pm, Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>> I can confirm that this one quickly solved the problem.
> Thanks for letting me know.
>> Sorry I didn't look for a fix.
> No need to apologize, I welcome the feedback from the testing.
> Chris
