After last patches libdl don't load rap files
Thu Feb 14 06:45:59 UTC 2019
On 14/2/19 5:26 pm, Сергей Круглов wrote:
> Hello!
> After last patches libdl don't load rap files. Not allocated memory for sections.
> You forget rtems_rtl_obj_alloc_sections before rtems_rtl_obj_load_sections in
> rtl-rap.c.
> Earlier rtems_rtl_obj_load_sections allocate memory for all needed sections. Now
> this in rtems_rtl_obj_alloc_sections.
> For correct need:
> rtl-rap.c:957
>   if (!rtems_rtl_obj_add_section (obj,
>                                   section,
>                                   rap_sections[section].name,
>                                   rap.secs[section].size,
>                                   0,
>                                   rap.secs[section].alignment,
>                                   0, 0,
>                                   rap_sections[section].flags))
>     return false;
> /** obj->entry = (void*)(uintptr_t) ehdr.e_entry; */
> * Allocate the sections.
> if (!rtems_rtl_obj_alloc_sections (obj, fd, NULL, &rap))
>   return false;
> if (!rtems_rtl_obj_load_sections (obj, fd, rtems_rtl_rap_loader, &rap))
>   return false;
Thank you.
Would you be able to send a git patch to devel at rtems.org?
Thanks
