AW: device-tree example for altera-cyclone-v bsp
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Thu Feb 14 13:37:42 UTC 2019
Hi Christian,
If your change is only regarding to the clock frequency then it should be possible to simply pass the value to configure:
configure --target=arm-rtems4.12  --enable-rtemsbsp=altera-cyclone-v BSP_ARM_A9MPCORE_PERIPHCLK=10000000U
At least that is what we do with the microzed board.
Cheers,
   Jan
Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
German Aerospace Center
Simulation and Software Technology | Software for Space Systems and Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
Jan Sommer
Telephone +49 531 295-2494 | Telefax 0531 295-2767 | jan.sommer at dlr.de
DLR.de/SC
> -----Ursprüngliche Nachricht-----
> Von: users [mailto:users-bounces at rtems.org] Im Auftrag von Christian
> Spindeldreier
> Gesendet: Donnerstag, 14. Februar 2019 13:55
> An: Sebastian Huber
> Cc: users
> Betreff: Re: device-tree example for altera-cyclone-v bsp
> Hello Sebastian,
> we had to change the BSP_ARM_A9MPCORE_PERIPHCLK frequency to 100
> MHz as
> this is the frequency the L4 MP clock is set by Qsys or the SPL,
> respectively. This meant adding a second board to the altera-cyclone-v
> bsp differing only by this configuration option. Adapting the
> configuration as described enabled the upstream RTEMS-5 version to boot
> on the Terasic-DE10 Standard Board (http://de10-standard.terasic.com).
> U-Boot itself contains a device-tree of the board it is running on, but
> i missed the u-boot command handing over the u-boot device-tree to rtems
> which expects the device-tree address in R6 on startup. If there is
> anything like this i am pleased on any information on it.
> Best Regards,
> Christian
> Using the described settings we
> On 13.02.19 19:57, Sebastian Huber wrote:
> > Hello Christian,
> > I add the BSP section to the user manual today. Unfortunately, I was not
> able to commit it. I tested also the latest RTEMS on the Cyclone V SoC
> Development Kit and it worked fine. Does it now run on your board? The
> device tree is normally provided by the U-Boot.
> Dipl.-Ing. Christian Spindeldreier
> Leibniz University Hannover (LUH)
> Institute of Microelectronic Systems
> Architectures and Systems Group
> Appelstr. 4, 30167 Hannover, Germany
> users mailing list
> users at rtems.org
