device-tree example for altera-cyclone-v bsp
Christian Spindeldreier spindeldreier at ims.uni-hannover.de
Mon Feb 18 17:45:30 UTC 2019
Hello Sebastian,
your changes work for us as well, now we are able to run a clean version
of the altcycv_devkit bsp on our DE10 board.
Extending the BSP documentation helps a lot, but maybe you can add the
definition of the u-boot 'loadfdt' variable, does not seem to be defined
in any socfpga configuration (e.g. socfpga_cyclone5_socdk) in the
upstream u-boot repo, but some other board configurations:
http://git.denx.de/?p=u-boot.git;a=blob;f=include/configs/socfpga_cyclone5_socdk.h
http://git.denx.de/?p=u-boot.git;a=blob;f=include/configs/socfpga_common.h
Kind regards,
Christian
On 18.02.19 09:17, Sebastian Huber wrote:
> Hello Christian,
> I added some basic BSP documentation:
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#altera-cyclone-v
> On 14/02/2019 13:54, Christian Spindeldreier wrote:
>> we had to change the BSP_ARM_A9MPCORE_PERIPHCLK frequency to 100 MHz
>> as this is the frequency the L4 MP clock is set by Qsys or the SPL,
>> respectively. This meant adding a second board to the
>> altera-cyclone-v bsp differing only by this configuration option.
>> Adapting the configuration as described enabled the upstream RTEMS-5
>> version to boot on the Terasic-DE10 Standard Board
>> (http://de10-standard.terasic.com).
> I changed the BSP initialization to use the device tree for this clock:
> https://git.rtems.org/rtems/commit/?id=af80b0a3406bef73dc6550421947a981c939da27
> It would be nice if you could test this. Please remove the
> "BSP_ARM_A9MPCORE_PERIPHCLK=100000000" from the configure command line.
>> U-Boot itself contains a device-tree of the board it is running on,
>> but i missed the u-boot command handing over the u-boot device-tree
>> to rtems which expects the device-tree address in R6 on startup. If
>> there is anything like this i am pleased on any information on it.
> The device tree provided by U-Boot is in r2.
Dipl.-Ing. Christian Spindeldreier
Leibniz University Hannover (LUH)
Institute of Microelectronic Systems
Architectures and Systems Group
Appelstr. 4, 30167 Hannover, Germany
voice : +49-511-762-5039
fax   : +49-511-762-19601
mail  : spindeldreier at ims.uni-hannover.de
web   : http://www.ims.uni-hannover.de/spindeldreier
