Waf's dependency on Python3
Jonathan Brandmeyer jbrandmeyer at planetiq.com
Tue Feb 26 15:57:56 UTC 2019
https://devel.rtems.org/ticket/3709
On Mon, Feb 25, 2019 at 5:32 PM Chris Johns <chrisj at rtems.org> wrote:
> On 26/2/19 10:18 am, Jonathan Brandmeyer wrote:
> > I attempted to follow the directions in rtems-libbsd's README.md and
> > run into the following error: "Could not create the directory ///h",
> > right after configuring the build.  On a wild guess I tried again
> > using python3 as the interpreter explicitly and that succeeded.
> > My host is Debian Stretch, AMD64.
> > /usr/bin/python is 2.7.13
> > /usr/bin/python3 is 3.5.3
> > Tested on rtems-libbsd current master
> > (5432c6bed37fa26a27c2730e34343d4c507902a9 as of this writing).
> > Its not entirely clear to me if waf is supposed to be dual-mode
> > compatible right now or not.  Maybe the waf shebang line should be
> > updated?
> Waf _should_ be fine, well that is the latest releases should be.
> We have our own support in the rtems_waf directory and that could be a source of
> what you are seeing so we cannot just assume waf.
> The weird thing is the path you posted '///h' looks like a Windows path but I
> cannot be sure.
> I suggest you raise a bug with as much detail as you think we need, eg commands
> lines and outputs.
> Thanks
> Chris
Jonathan Brandmeyer
Engineering Director
PlanetiQ
