Issue in hello world test
Tue Feb 19 08:04:10 UTC 2019
On 19/02/2019 08:42, Humaid Bin Haroon wrote:
> Hello,
> I am having an issue on running the hello world test as directed on
> https://devel.rtems.org/wiki/GSoC/GettingStarted .
> Please find below the gdb output for the test using sparc-rtems5.
> *** BEGIN OF TEST HELLO WORLD ***
> *** TEST VERSION: 5.0.0.bdec62c4d5aa25e5a98b9fafe78936a7beb96a6e
> *** TEST STATE: EXPECTED-PASS
> *** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
> *** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB
> 98588a55961a92f5d27bfd756dfc9e31b2b1bf98, Newlib 3e24fbf6f)
> Hello World
> *** END OF TEST HELLO WORLD ***
> *** FATAL ***
> fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
> fatal code: 0 (0x00000000)
> RTEMS version: 5.0.0.bdec62c4d5aa25e5a98b9fafe78936a7beb96a6e
> RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB
> I would like to know why am I getting RTEMS_FATAL_SOURCE_EXIT?
> I had no errors during installation, bootstrapping or building .
This fatal error sounds more scary than it is. It is documented here:
https://docs.rtems.org/branches/master/c-user/fatal_error.html#fatal-sources
It is the result of someone calling exit(0).
> Also on testing the BSP using ‘rtems-test --rtems-bsp=erc32
> --rtems-tools=$HOME/quick-start/rtems/5’ I got one failed test:
> Passed:        582
> Failed:          1
> User Input:      5
> Expected Fail:   0
> Indeterminate:   0
> Benchmark:       3
> Timeout:         2
> Invalid:         0
> Wrong Version:   0
> Wrong Build:     0
> Wrong Tools:     0
> Total:         593
> Failures:
> dl09.exe
> Can someone please assist me as I am new to RTEMS .
Looks good, the dl09 is due to some recent changes in the libdl.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
